Re: Farmall 300 crankshaft
Posted by super h man on September 15, 2013 at 02:38:02 from (37.228.111.142):
In Reply to: Re: Farmall 300 crankshaft posted by Zachary Hoyt on September 14, 2013 at 04:36:24:
H crank will fit in the 300 block. order H bearings. H rods will work too, if your using the same pistons you have now with the big pin pistons, then the H rod will swap right out with the 300 rod. if your ordering a new sleeve n piston set, they will be small wrist pins so youd need the adapter bushing to se small pin piston in the H rods.
