Posted by Nebraska Cowman on September 15, 2013 at 03:22:26 from (66.252.116.102):
In Reply to: Re: Farmall M Magneto posted by Two Banger on September 14, 2013 at 16:37:14:
New key switch? You can buy key switches that ground the spark when shut off. (lawnmower applications) It may look the same to you as a switch that is made to put spark to a distributor but they are different animals. Try running your tractor with the magneto wire unhooked and see what happens. It should start and run with the wire unhooked. Then use a separate switch to ground that terminal to ground and stop the engine.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
