Re: belly pump plumbing question
Posted by Zachary Hoyt on September 15, 2013 at 08:15:20 from (184.12.74.26):
In Reply to: belly pump plumbing question posted by BigTone on September 15, 2013 at 08:10:51:
I do not know if there is a way to run them both at once but I think not unless you set it up so you have two valves, one for each. It is not that hard or expensive to use quick couplers, and then all you have to do is hook up whichever you need.
Zach
