Cheapest way if the mower cylinder only uses one hose with gravity down and you have a drawbar on with the 3 point. Put a quick coupler in the line to 3 point cylinder to change from one to the other. Or if you have a double acting valve to the 3 point and one line to mower. Hook on another side port of the liftall and use it to raise and lower the mower. Depends on the plumbing, you may still need a disconnect or a shut off to the double acting valve if used that way. Or you can get a valve to switch one valve to two circuits, but more plumbing and cost.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
