Re: 1066 Noisy Transmission
Posted by The tractor vet on September 15, 2013 at 10:43:34 from (75.19.125.100):
In Reply to: Re: 1066 Noisy Transmission posted by DeltaRed on September 15, 2013 at 07:50:39:
Did you have to add any shims'' behind the quill?? If you did then did you shim the gear on the lower countour shaft with the same shim ?? did you tighten up the countour shaft nut tight then back off then re SNUG and drill the nut and install the 1/8th inch roll pin??
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
