Re: 656 international 2 point hitch
Posted by The tractor vet on September 15, 2013 at 12:15:20 from (75.19.125.100):
In Reply to: 656 international 2 point hitch posted by Herb W on September 15, 2013 at 11:47:38:
I use to make some of them that were adjustable for Cat 1 and Cat 2 . They were not had to make as i made up a jig to get all the pieces tacked into the correct location then i would weld them up . The hard part was coming up with the stock for the points as it is NOT a standard size bar stock and i had to order it in in 40 foot lenghts and they would cut that down for me to haul. the rest is just made out of 1/2 x4 bar stock and schedule 80 1/2 in tubing and two grade 8 bolt for each point . The ones i made up were strong enough that you could pull a 5 bottom plow with . I am still usen the last set i made over ten years ago.
