Grinding sound from transmission case
Posted by jeffred on September 15, 2013 at 13:33:57 from (208.126.231.218):
I know I have read about this on here before but I cant seem to find it, but I have a grinding type noise that comes from the transmission case of a BN when it is in neutral. It seems to get a little better when I push the clutch in. Is this something to worry about and if so, what needs to be replaced? It was making this noise both before and after I changed the tranny oil.
