Re: Hydraulics....
Posted by John G. Hasler on September 16, 2013 at 05:30:13 from (174.124.82.31):
In Reply to: Hydraulics.... posted by John M on September 16, 2013 at 03:25:30:
> Running off of belly pump via a secondary valve.
> Hose from the pump to the valve, hose from valve
> to cylinder(s), one hose dead heads with a
> coupler for use on implement previous owner had.
> Now, the valve is what I call a 3 position, up,
> neutral, and down.
No return line?
