Posted by D Slater on September 16, 2013 at 13:51:53 from (184.14.177.70):
In Reply to: Re: Hydraulics.... posted by John M on September 16, 2013 at 11:47:30:
I used a valve just like that one before on a M single acting cylinder loader to control drop. Just run a pressure line to inlet on the valve. Return line port to lift cylinder or cylinders. Plugged one valve outlet and run a hose from the other outlet to the drain opening on the reservoir. Pull the liftall rod to raise, then move the valve lever one way for drop. If that valve won't work like that or the other way I mentioned, there's something wrong with it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
