Posted by Dave Allgire on September 16, 2013 at 15:04:19 from (24.217.48.166):
In Reply to: F12 problems... posted by arkfisher on September 16, 2013 at 10:09:41:
I at one time had the same problem. It didn"t want to start, but when it did, it would run rough and you could really hear the impulse working until after about 12-15 impulses. When you are timing your mag, make sure the pointer (#2) on your rotor is pointing in the exact direction. I"m assuming you are lining up the #1 piston on TDC of the flywheel. Another thing I found is the pawl of the impulse coupling can be worn and/or dry. If you have the mag off of the tractor, you can lubricate the pawl/impulse assembly. If it is still on the tractor, put a few drops of oil in the lubricating port on top of the impulse cover. Hope this helps, at least its someplace to start.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
