Posted by The tractor vet on September 16, 2013 at 16:28:14 from (75.19.125.100):
In Reply to: 1466 leak posted by BigTone on September 16, 2013 at 10:35:44:
Well if the leak is at the bell housing then you IDPTO shaft seals are leaking and what usually causes that is that the input shaft for the pto is getting wore along with the pressure plate . Now if the leak is at the split between the torque tube and the rearend then you may have some bigger problems and this is where your dropping prime on the hyd. system mainly the MCV system where you have no steering , brakes and no T/A function . Picture my boy i need pictures to see what is going on cause i ain't maken a service call .
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
