Re: F12 problems...
Posted by Craig45 on September 17, 2013 at 07:50:30 from (108.45.20.161):
In Reply to: F12 problems... posted by arkfisher on September 16, 2013 at 10:09:41:
Try a squirt of starting fluid in the intake before you crank it. I
have two f 12"s one starts right up but the other is hard to start
unless I use a little starting fluid. I don"t know why this is. I
have gone through the carb and mag and everything seems to
be set right. Did a compression check and all cylinders are
between 60 and 65 lbs. don"t know if this is low or not. Let us
know if this helps you.
