Posted by tmiller on September 17, 2013 at 09:34:35 from (205.133.149.127):
In Reply to: Setting Carb on 48H posted by Farmallb on September 17, 2013 at 08:46:28:
Most likely the idle screw in the carb, if you followed these and it didnt work im not sure... every one that I have ever worked with at the shop idled nicely after a carb adjustment. Unless its a fuel problem then it would putter out so i do not believe it is this. --taylor
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
