Posted by Janicholson on September 17, 2013 at 16:10:42 from (199.17.6.25):
In Reply to: Setting Carb on 48H posted by Farmallb on September 17, 2013 at 08:46:28:
If the throttle plate in the carb is misaligned with the throttle bore, it will hang part way open. This is simple to fix. Loosen the screws in the throttle shaft holding the plate, loosen the idle screw so it will not touch the lever, (may be there now) and center the plate well so it seats in the bore, and retighten. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
