The firing order is 1342 from the front of the engine. Take out #1 plug, put your thumb in the spark plug hole (or hold a tapered cork in the hole gently) then rotate the engine in short bumps (coil wire grounded to avoid unpleasant shocks). When the air is pushing out of the hole, it is on compression stroke. a little further turning with the fan, or pushing it in high gear will allow you to get to TDC, or very close. (put a straw in the Spark plug hole to see the piston move up as you push the tractor. Remove the dist cap and that is #1 from there (in the direction of rotation (Clock wise) it is 3 then four then 2. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
