Posted by 36F30 on September 17, 2013 at 16:28:01 from (97.125.157.45):
In Reply to: F12 problems... posted by arkfisher on September 16, 2013 at 10:09:41:
You told us last time that this tractor crank started with the original carb, you then changed the carb to a brass one and now it won't start with the crank. That tells me something is not quite right in your brass carb. F12s can be very touchy starters, you need to check and double check everything in that carb from float level to every nook and cranny in every passage. You may need to adjust the jets a little at a time until you hit the sweet spot. Play with the throttle position..etc etc... until you find it.
As for using starting fluid in a hand crank tractor. That may just be the worst piece of advice ever given on here. These tractors can and have hurt/killed people during a kickback. This is why everyone advises you to use only upstrokes and tuck your thumb. Just a touch of either would compound the kickback drastically. If you want to use it go ahead, its your arm, but I would never ever recommend using it to anyone else unless using a belt or pull starting the tractor.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
