Re: Setting Carb on 48H
Posted by Farmallb on September 18, 2013 at 05:29:12 from (97.73.64.149):
In Reply to: Re: Setting Carb on 48H posted by jal-SD on September 17, 2013 at 19:57:27:
Yes I put a new kit in it. IF it is not matched up, would I have a full range of rpms? Could I pull with it, which I can?
