Posted by newcubguy on September 18, 2013 at 08:38:26 from (24.32.225.56):
In Reply to: Re: pto disengaging posted by gene bender on September 18, 2013 at 06:22:45:
After looking things over real good I have determined that the splines are wore out on the input shaft and on the back side of the collar that slides up on the shaft. Also it looks like the input shaft has moved back away from the PTO shaft. Those brass bushings on the pilot shaft are worn.I figure I'm going to have to split the tractor. Do I split it at the bell housing by the motor or back by the gear shift? Thanks
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
