Posted by JimB2 on September 18, 2013 at 12:24:37 from (99.241.76.141):
In Reply to: 885 diff lock posted by deereabhm on September 18, 2013 at 08:16:53:
Hi from archives: Differential Lock: If the differential lock is stuck locked on or if it doesn't lock. Check the pedal for free movement, it has a shaft that actuates the lock fork, the shaft is below the hitch cover and the link from the pedal hooks onto it. Often it has rust on the shaft where it turns on the rear housing. Try to spray a good lube on the shaft or you may have to lift the cover and remove the shaft and clean it. Bernard le mécano Québec Canada
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
