Re: Loader Issues
Posted by farmallman1949 on September 18, 2013 at 14:01:10 from (70.195.67.81):
In Reply to: Re: Loader Issues posted by mkirsch on September 18, 2013 at 06:06:32:
Air in the cylinders is most likely the cause. Not only is this a pain in the @(# it can be very dangerous. The simple thing to do is just loosen the line that feeds the side of the cylinder that is causing the problem (as you are sitting on the tractor either the front or back fitting) and work the up and down lever until oil is coming out of the fitting without air bubbles just be sure and do both sides of the loader at the same time or it will just push the air from one side to the other. If this does not fix it then take a look at the valve system.
