Re: Ps gauge bracket
Posted by D Slater on September 19, 2013 at 07:19:16 from (184.14.177.70):
In Reply to: Ps gauge bracket posted by DTK on September 18, 2013 at 16:57:38:
None of the ones line up perfect that I have had contact with. Don't know of any with the wing nut stud.
Made my own mount that lines up with shaft and with the hood support and stud. But to get the torque generator mounted in line with the worm shaft, the front of the fuel tank was raised about 3/4 inch and the rear a little more and then the bottom of the radiator moved back and the front tilted forward to make the sheet metal look matching. Raise was done so hood would clear the torque generator and not rub.
New mounts or original charlynn ones seem to mount the unit lower than perfect alignment at the rear of unit to get hood clearance.
May be some better one out there that I haven't tried.
