Re: FARMALL 806
Posted by pete 23 on September 19, 2013 at 17:45:27 from (173.87.147.33):
In Reply to: FARMALL 806 posted by Josh and Diana on September 19, 2013 at 17:22:43:
What is the red light showing you. It should go on with key on and engine not running. It should be out at all other times except when you put clutch in to shift gears. Here are some of your possible problems. That little plastic valve in lower right corner of clutch housing got left out, installed gasket for tractors without TA inside or left out an o-ring inside. Might even have installed regulator valve backwards. You need to look at a good layout of the valve to get all parts installed correctly.
