Re: Farmall H (gasoline evaporation)
Posted by mkirsch on September 20, 2013 at 05:24:30 from (64.80.110.74):
In Reply to: Farmall H (gasoline evaporation) posted by Red in KS on September 19, 2013 at 17:48:33:
I know you said your carburetor isn't leaking, but...
Your carburetor is leaking.
I've got a Cub, that if you don't shut off the fuel at the sediment bowl, the gas will "disappear."
You can't tell that it's leaking unless you catch it at just the right time. Then you will see ONE drip.
There is no "moisture" or discoloration on the carburetor. There is no smell of raw gas. There is no stain on the ground.
Once I accidentally left the fuel on all winter, and lost about 5 gallons of gas. Turn off the gas, and it doesn't lose a drop.
