Re: 1949 Farmall - H...Hydraulic oil leak...need some advice
Posted by Raner on September 20, 2013 at 07:24:01 from (173.175.94.231):
In Reply to: 1949 Farmall - H...Hydraulic oil leak...need some advice... posted by Raner on September 19, 2013 at 12:30:15:
Ok...
Removed the controller assembly from the tractor...
I'm trying to remove the shaft to replace the seal but don't want to mess up...
Is the gear just pressed in the shaft, I can see a key slot where
the gear against the shaft, and that baby is on tight...
More questions later when I start putting it together...some stuff
came apart and need to figure where it goes...Thanks Raner...
