Cold start results on F460
Posted by kev@IA on December 02, 2000 at 11:02:40 from (207.177.4.55):
I said I would get back to you all after trying to start the tractor in colder weather. At 10 deg it still started and it had set for over a week, took quite a few trys to get the right choke position. I will pull the plugs next and see if new ones will improve things some. Still at 4 deg of advance on ignition at low idle. Once it caught well it ran fine and took less choke than when ignation was stuck advanced 25 deg.
kev
Post A Followup
: Re: Cold start results on F460
