Posted by mkirsch on September 20, 2013 at 11:04:31 from (64.80.110.75):
In Reply to: Double bevel rim posted by MoCoJo on September 19, 2013 at 11:25:13:
I've heard it done by installing two lugs 90 degrees apart. Then you set the rim on those lugs, aligning the bumps in the rim to the lugs. Work around from there.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
