Posted by Janicholson on September 21, 2013 at 16:03:01 from (74.60.94.18):
In Reply to: Gas tank Farmall H posted by charlespretzer on September 21, 2013 at 15:21:48:
There is a baffle in the tank. If it is loose, it will possibly wear a hole in the tank. If you can bend it such that it no longer vibrates against the internal surfaces, that would probably be the easiest. If it is way loose, removing it is the next solution, but the fuel would slosh. The best option is to get a different tank, there are many H tanks in existance with no tractor attached. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
