Re: Mowing with 48 H
Posted by Janicholson on September 21, 2013 at 16:07:45 from (74.60.94.18):
In Reply to: Mowing with 48 H posted by Farmallb on September 21, 2013 at 14:20:36:
You can put a one way restrictor in the line. this passes full flow down, but restricts up. Many sources are out there. Surplus center is one.
Another thought is to change the leverage to make the cylinder move farther when lifting, or using a bigger cylinder diameter. Jim
