Re: electical question
Posted by Bob M on September 21, 2013 at 18:08:27 from (69.207.87.207):
In Reply to: Re: electical question posted by rosedale123 on September 21, 2013 at 17:11:22:
third party image
Nope! Behind the D-shaped hole in the rear of the alternator there's a metal tab (photo). Use a small screwdriver, or similar to ground the tab to the side of the hole. This will bypass the regulator.
If the alternator is good should see 14 - 15+ volts at the battery with the engine at speed and the regulator bypassed.
Also it sounds like your ammeter is stuck (it should show -3 amps or so when you turn on the ignition.) Test by bringing a small magnet to the face of the gage and moving it around. The gage hand should move freely away from center in both directions as you move the magnet.
