Re: wont run after new carb install
Posted by janicholson on September 22, 2013 at 15:58:33 from (74.60.94.18):
In Reply to: wont run after new carb install posted by pisgah ihman on September 22, 2013 at 14:42:34:
There is a filter in the line at the carb fitting. the sediment bowl, and the pipe that connects the sediment bowl to the tank. (which tractor makes a difference) there should be a steady stream out the carb bowl drain into a can test for more than one minute. If it slows or stops the supply is the issue.
Electrical issues can act that same way. If this is the first it has run it could be ignition, not fuel. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
