The top bushing under the sector (flat gear) is often worn. when worn it allows the esctor to move away from the worm. The worm bushing (steering wheel side of box) and the ball bearing on the front can be worn as well. There is no adjustment other than correct bushing bearing clearance. Check those first. Also check all U joints in the shaft, the bottom bushing, and the tire balance. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
