Re: Farmall 450 Front End Wobble
Posted by robgIN on September 22, 2013 at 18:35:56 from (70.224.32.29):
In Reply to: Farmall 450 Front End Wobble posted by jboyer1028 on September 22, 2013 at 13:12:29:
in addition to the bushings, the shaft itself may be worn if it has seen a lot of use. Had bad wobble in our SM, replaced the bushings and had to build up the worn spot, turn it back down, then installed it 90degrees from past position. Now we can go down the road wide open with no wobble at all.
