Re: Has anyone ever had a problem with
Posted by justin on December 02, 2000 at 19:57:21 from (209.23.129.57):
In Reply to: Has anyone ever had a problem with posted by Farmer Bob on December 02, 2000 at 18:45:01:
What you have are rod and main bearings that fit the late H thru 350. The Hs serial number 391358 and up use the bearings that you have (2105Sb for the rods, and 941M for the main bearing set).. I would suggest that you not stay with standards, but rather buy 0.002 bearings due to some of the journals being .005 out of tolerance. Case IH will just sell you Federal Mogul bearings, so just take the ones you have back and order the correct ones for your tractor (1105SB for the rods, and 577M for the mains) Hope this helps..
Post A Followup
: Re: Re: Has anyone ever had a problem with
