Posted by RustyFarmall on September 23, 2013 at 11:18:37 from (216.248.71.226):
In Reply to: Hyd fill level on H posted by Farmallb on September 23, 2013 at 10:36:17:
If there is not enough oil in the reservoir to fully extend the cylinder/cylinders, add more oil until it functions as desired. If you get TOO much oil in it, the excess will spew out through the vent hole in the fill cap and make a mess, but no other damage will occur. If you aren't using the belly pump, it still needs SOME oil in it. You can fashion a dipstick from a length of #9 wire. Just insert the wire, pull it back out, and see where the oil level is. It won't be accurate by any means, but at least you will know there is some oil in there. Add 1 quart at a time until you are satisfied.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
