Re: Farmall H generator amperage
Posted by redandgreen on September 23, 2013 at 14:26:21 from (66.87.73.178):
In Reply to: Re: Farmall H generator amperage posted by redandgreen on September 12, 2013 at 17:37:00:
Well, got to work on the H today. Tried
everything. Moved the brush closer to the
closest fixed brush (the one with the wire
going to the Armature terminal, not the
bush that's grounded) and gained a whole
amp. Charged at 4 amps according to the
gauge. Tried cleaning generator mounting,
cut out mounting, field and aramture
terminals on cut out and generator. That
helped a bit. Got it up to 6 amps. Tried
running a new field wire, actually got
worse amperage - around 4 amps using 12 ga
wire. Tried dedicated ground from box to
positive post of battery, still 4 amps.
Think I might get a new harness. Found a
bunch of bare spots through the original
cloth insulation. Is six amps all I'm
going to get out of it at 3/4 throttle?
With the lights on high beam, it still
shows discharging at about 4 amps or so.
Better, but not ideal I would think.
