Re: Firecrater pistons in 1950 H
Posted by D Slater on September 24, 2013 at 05:13:49 from (184.14.160.234):
In Reply to: Re: Firecrater pistons in 1950 H posted by PretendFarmer on September 24, 2013 at 04:09:22:
third party image
third party image
third party image
Most times a head casting number can be found on top under the valve cover. But you should also be able to find a date code on the top of head between the valve cover and the manifold. have to clean or look between the head studs and nuts. If the date code matches the rest of tractor it probably has the original gas head. Since the tractor came as a gasoline the head would be a # 8043DC.
Going to ad pictures. First would be a common aftermarket. second a IH firecrater. Last a step head type IH and aftermarket. Some aftermarket did and do make a firecrater look alike for some engines.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
