Posted by Ellis Kinney on September 24, 2013 at 13:08:54 from (74.139.97.108):
Farmall M steering loose and sloppy as it can get. I just received my new used steering worm gear and shaft from Bates Corp. Bermuda Ken had a bushing and bearing kit like someone suggested. I have shimmed the upper steering shaft with a thin piece of copper and it turns freely. The universal joint is adjustable with thin washer shims and I have removed the slop in it. The sector gear is worn on about 5 teeth. Is it a good idea to re-install it 180 degrees from where it was? It seems logical. The vertical shaft has some wear, but I think I can use it over, considering the price to get it built up and turned. Anything I haven't thought of yet? Thanks, Ellis
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
