Re: Cub Farmall Throw out bearing question
Posted by gene bender on September 24, 2013 at 14:24:34 from (67.55.227.222):
In Reply to: Re: Cub Farmall Throw out bearing question posted by Farmallb on September 24, 2013 at 09:11:37:
NO you have a graphite thro-out bearing and its not supposed to ride on the shaft its job is to push against the fingers on the pressure plate
