Before reassembling the cub, check the height of the fingers on the throwout bearing, they should clear the back of the pressure plate by 1 1/4 inch, and must be even. If you did not buy a bearing from IH, soak it in 10 weight oil for a couple days before installing. Grease it yearly with cheap grease. It is lubricated by the oil separating from the wax base and soaking through the graphite to the front. If you use high temperature grease the graphite does not get lubricated.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
