Adjusting the register means ensuring the knife sections start the stroke with the tips inside the guards and end their stroke with the tips inside the guards.
Adjusting the cutter bar lead means moving the outer end of the cutter bar forward or back.
The mower frame should be level when attached to your tractor.
The outer shoe should lead the inner shoe slightly.
You can set cutter bar height by altering the sole settings on the inner and outer shoes.
You can adjust the tilt with the cast iron tilting knob.
The pto shaft should run straight - you should not be making the two universal joints work hard.
Do you have an Owner's Manual? Happy to give you one. It has all the settings and correct dimensions.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
