Posted by Owen Aaland on September 25, 2013 at 09:05:58 from (216.47.35.219):
In Reply to: ihc 3688 hydrualics posted by Andy Kitching on September 24, 2013 at 18:56:27:
If just the loader and hitch quit working the most likely cause is a relief valve stuck open. Other possibilities would be a blown O-ring or a failed pump.usually if you have an O-ring failure you will have a slight bit of hydraulic pressure. Sudden pump failures are unusual but two possibilities there would be a broken pump shaft of the gear came off the pump. I would bet on the relief valve being stuck open.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
