Welcome to the forum. I like the tractor you have, and think you got a great deal. Were it mine I would fix the leaks and leave the remote hookups. you might want to use front mounted items or remote equipment like a splitter or post pounder. What you stated made sense, I just would not remove hydraulics. Most 3 point equipment will need individual leveling and control. Opinions will vary but the best is to buy that which you need (including some FH equipped implements. The draft control is basically not operational on the FH of that series, so operating the 3 point will be interesting as many types of tools rely to a degree on good draft control. Even the 35oU has poor draft linkages. You will learn to control plow depth and other in the ground tool depth using the FH control. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
