Posted by jiminy on September 26, 2013 at 04:47:17 from (216.227.61.96):
In Reply to: ihc 3688 hydrualics posted by Andy Kitching on September 24, 2013 at 18:56:27:
I have one of these and have experienced about every problem one can have with it..first the hitch pump is located down behind the rear tire on the clutch side..valves are on the oppisite side. the o ring mentioned sounds as if it could be your problem if things went away gradually. it is located in the pump mounting plate to remove you must drain all hyd oil and remove plate..pump will come with it..pump can be inspected when you do this..when the pump shaft breaks its usually still on pump but you can turn it easily..if its good it should be difficult to turn. post back and let us know what you find.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
