Re: 560 hydraulic lever
Posted by pete 23 on September 26, 2013 at 10:19:03 from (74.33.77.105):
In Reply to: 560 hydraulic lever posted by Dirt on September 26, 2013 at 08:21:08:
Moving lever to the rear should raise the hitch on a 560. The normal mix up on these is that the previous tractors like a 450 were the opposite. However,the 450 did not use teledepth valve with follow up linkage. Now if someone has removed the teledepth valve and linkages and installed a regular valve , you could reverse the hoses and get by. If it still has teledepth with linkage to hitch, reversing the hoses will damage parts, most likely the differential gears in the valve,and of course it will not work.
