IH Model 60 plow
Posted by wicksfield on September 26, 2013 at 16:08:08 from (67.236.244.37):
I got a 3 bottom model 60 plow from a buddy that
needs some attention. Please advise on the
following:
1. The furrow wheel has a 15" tire while the land
tire is 14". Is this correct?
2. The coulters need to be changed. What size
should I install and should they be straight or
wavy?
Thanks in advance for your response. (I posted
this identical question on redpowermagazine in
case someone misses it.)
