Posted by EvanB on September 27, 2013 at 04:40:32 from (174.57.53.238):
In Reply to: 300 sheetmetaal posted by farmall4856 on September 27, 2013 at 04:09:48:
It sounds like a common problem that occurs when the "flash time" of the paint is not followed. "Flash Time" is the amount of time needed to allow all the "solvents in the paint to breath off. Putting several heavy coats of paint on top of each other will trap the solvents and it will cause the paint to bubble, peel, or whatever. Same principal applies to the clear coat application. Each paint manufacture has specific Flash times or "recoat" times listed on the can or website. Other possible issues that can contribute to your issue is temperature changes, humidity levels so on so forth.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
