Re: 560 hydraulic lever
Posted by mkirsch on September 27, 2013 at 06:45:05 from (64.80.110.74):
In Reply to: 560 hydraulic lever posted by hayshaker5 on September 26, 2013 at 10:58:28:
If they didn't have fast hitch how were they "opposite?"
On implements, if you don't like the way the up/down works, all you have to do is switch the hoses around.
You can't do that on a 560 Teladepth because there is a feedback linkage that senses the position of the hitch and turns the pressure off. If you switch the hoses around, the hitch will go all the way in one direction and stick there with the hydraulics on high-pressure bypass through the relief valve. After about 5 minutes of that you'll burn up the hydraulic pump.
