Draw bar itself is not that wide - to get a 2 1/4 ball size hole would leave little meat on each side.
The swing part of the DB on the SC is right under the rear of the axle which means the pivot point would be right under the rear, cutting down on the ability to make tighter turns.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
