Re: 300 sheetmetaal
Posted by CNKS on September 27, 2013 at 16:54:06 from (216.144.104.128):
In Reply to: 300 sheetmetaal posted by farmall4856 on September 27, 2013 at 04:09:48:
Evan gave you the correct answer--If you wait too long between coats the paint will lift. With quality paint you should be able to apply coats 5-10 minutes apart, or until it flashes or begins to dry. If you are using clear, you should be using the base-clear system, there are specific instructions from PPG, DuPont, etc. If you are mixing brands of paint you are taking a risk of something going wrong.
