Posted by Tom Fleming on September 28, 2013 at 18:28:42 from (67.20.233.75):
In Reply to: Running lean posted by Ellis Kinney on September 27, 2013 at 17:13:45:
Yup, Hugh pretty much nailed it. Summary: running lean is bad period. These older engines especially, will chew up valves and valve seats just about as quickly as you can replace them. Some of the relatively newer, higher compression number series, will gall pistons/cylinders as well. For years, I run what I own a wee bit rich.....not enough to heavily soot the plugs, but enough that I don't have valve issues.
Octane is required for one thing: compression
If you don't have a higher compression engine, you don't need the higher octant. Any letter series or older will run very very happily on 87 octane. If your engine isn't running well on it, you have other problems: faulty carb, incorrect timing, leaky valves, poor ignition. Look there and don't worry about the 87 octane.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
